IDS-4215 Upgrade
Mar 4th, 2009
Hello - I sucessfully used the IDM to upgrade the IDS 4215 using IPS-K9-r-1.1-a-6-0-5-E3.pkg. But now how do I force the IDS to use the new code? It show in the 'recovery Partition' .. tnks
MainApp 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600 Running
AnalysisEngine 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600 Running
CLI 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600
Upgrade History:
* IPS-K9-sp-5.1-5-E1 20:58:00 UTC Fri Feb 02 2007
IPS-sig-S296-req-E1.pkg 16:15:16 UTC Fri Aug 10 2007
Recovery Partition Version 1.1 - 6.0(5)E3
marcabal Wed, 03/04/2009 - 11:38
if you are trying to upgrade from 5.1(5)E1 to 6.0(5)E3, then you've loaded the wrong file.
The IPS-K9-r-1.1-a-6-0-5-E3.pkg is a Recovery file (the -r- in the name is the designator for a recovery file).
The recovery file is for changing what is in the sensor's recovery partition.
The recovery partition is only used when you've seen problems on a runnning system and need to get back to a good running version.
It is not for upgrading from an older version to a newer version.
You will want to download the 6.0(5)E3 upgrade file instead:
Go to the main IPS download page:
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875311
Select IPS Appliances, select IPS 4200 Series Sensors, and select the IDS-4215.
Then select the "Intrusion Prevention System (IPS) System Upgrades". the "System Upgrades" is where the upgrade files are located.
Then in the Latest Releases folder select the 6.0(5)E3 version.
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=6.0%285%29E3&mdfid=278244333&sftType=Intrusion+Prevention+System+%28IPS%29+System+Upgrades&optPlat=&nodecount=3&edesignator=null&modelName=Cisco+IDS+4215+Sensor&treeMdfId=278875311&treeName=Intrusion+Prevention+System+%28IPS%29&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
You will want to download and install the IPS-K9-6.0-5-E3.pkg file.
sdoherty Wed, 03/04/2009 - 12:12
Excellent - worked and now IDS is up on Version 6.0. tnks! New GUI -very nice..
I also loaded the latest sig file. tnks!
