Changing Active-Directory-Synchronized CCM fields !!??
Answered Question
Hi all,
Is there a way to change the department of CCM users synchronized with an Active Directory ?
The question applies also to :
Middle Name
Manager ID
Department
Phone Number
Mail ID
Which are parts of the "Fields to be synchronized" in the LDAP directory Information Form.
best regards,
Correct Answer by Jaime Valencia about 8 years 1 month ago
yes, change it in AD
if you cannot change a field in CUCM is because you need to perform the changes directly in AD
no, it's not possible not to include it
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 03/04/2009 - 10:50
  • Cisco Employee,
  • Hall of Fame,
    2011
the information is on the SRND and when you create the integration you get to choose from fields that have 2 or more values. if there is no option you obviously cannot choose.
Table 18-4 Data Attributes Imported by Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/directry.html#wp1045145
java
I meant that , actually, it is not possible to change the Department of a user once we have performed synchronization with an Active Directory .
Is there a way/trick to change this field although I have a Synchronization in place ? or at least, is it possible not to include the department field in the fields that are aynchronized with the Active Directory.
Hope I got more clear than the first time.
best regards,
Correct Answer
Jaime Valencia Wed, 03/04/2009 - 10:59
  • Cisco Employee,
  • Hall of Fame,
    2011
java
