Meetingplace 6.0 installation Softwares names
mightyking Thu, 03/05/2009 - 06:53
Make sure both phones are part of the same Pickup group. Also make sure both phones CSS contain the partition of the Group Pickup number.
Have a look at this great threat:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1606f
mightyking Thu, 03/05/2009 - 07:01
I don't think you can download the software through downlaod center. I think it's only avaialbe on DVD. You need to contact your sells rep.
MK
calmichael Fri, 03/06/2009 - 15:20
While you can download just about everything from CCO you need except the OS boot/detection media (1.1-1.4); you won't have an operational setup without an 8106 or 8112 appliance as it is the device that mixes/blends the audio streams, serves as the licensing node, and is the node to which all the Windows 2003 based components register to.
Cheers
