ether channel fiber connections
can someone please tell me the config commands to set up ether channeling between 2 multimode fiber connection on a cisco switch. when i initial configured and plugged in my fiber there was traffic then it stopped and the ports shut down. no link lights at all. when i remove ether channel groups traffic resumes. i've editing the config so much i'm not sure what i changed and should keep at this point. thanks for any help.
current config
switchport mode trunk
switchport non negotiate
spanning tree port fast trunk
i'm getting this when i do a show ether channel "port state down - not in bndl" what bundle?
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 03/04/2009 - 12:20
Is this a layer 2 etherchannel ? if so then you need a channel-group command ie.
assuming your 2 fibre ports are gi1/3 & gi1/4
6500(config)# int range gi1/3 - 4
6500(config-if-range)# channel-group 1 mode on
this then creates a port-channel interface for you. Note i have used channel-group 1 in the above, you need to use an unused number for the channel-group as 1 may already be in use.
So you have a port-channel interface. Configure it as follows
int po1
Make sure the speed/duplex settings are same on both gi ports.
Attached is a link to configuring etherchannel on 6500, principles are same for most switches -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/channel.html
Jon
adamclarkuk_2 Wed, 03/04/2009 - 14:56
Could this be because the config is different on the physical interface and the Port Channel. Default the config on the physical interface using the default interface command. Then just make the physical interface a switchport and a trunk, then add it to the port-channel with the 'channel-group x mode on command' and add all the needed details to the Port-channel and see if that helps.
CORE Stack Switch
interface Port-channel10
switchport nonegotiate
spanning-tree portfast trunk
end
interface GigabitEthernet4/0/49
description Fiber connection to IT switch port 26
channel-group 10 mode on
end
interface GigabitEthernet5/0/50
description to IT Switch port 25
end
Stand alone switch
interface GigabitEthernet1/0/26
description Fiber connection to Data Center port 49
end
interface GigabitEthernet1/0/25
description Fiber connnection to Data Center port 50
end
adamclarkuk_2 Thu, 03/05/2009 - 07:45
You haven't assigned the Stand alone switch interfaces to a Port-channel.
Both ends need to be configured as a port-channel for it to work.
adamclarkuk_2 Fri, 03/06/2009 - 07:22
Put the config back is it should be, (ie the Port-channel on both switches) then re post your configuration.
CORE Stack Switch
end
end
end
Stand alone switch
end
end
end
adamclarkuk_2 Fri, 03/06/2009 - 08:20
If you are using CDP, issue the command 'show cdp neighbors' to make sure you have the right interfaces connected and configured as he config looks good.
glen.grant Wed, 03/04/2009 - 17:38
Your best bet is to post both sides of the configs so we can see each end .
