ip extended ACL
Mar 4th, 2009
When looking at one of our ACLs I sometimes see the port number after the source instead of the destination. Such as:
permit udp any eq 1434 any
What is the difference between putting the port after the source and after the destination?
adamclarkuk_2 Wed, 03/04/2009 - 12:39
What you are matching there is
Any source IP on udp port 1434 only
Any destination IP on any udp port number
So you can see with extended ACL's you can get really granular.
Richard Burts Wed, 03/04/2009 - 14:50
The difference is whether the access list will check the source port of the packet (if you specify the port after the source address and mask) or check the destination port (if you specify the port after the destination address and mask).
