2851 Module Help
Answered Question
Mar 4th, 2009
I'm in the process of adding a T1 to a current voice gateway and have a question on some of the slots on a 2851.
Current module Use:
Interface Card Slots:
- 2 vic-4fxo
- 1 vwic2-2mft-t1
- 1 vic-4fxs/did
Also theres an NM-HD-2VE with 2 x vic-4fxs/DID cards in it
I need to add another T1 Interface (for data). Only t1's for data are available form the service provide as the client is in the sticks.
I'm not sure if I can order NM-HD module and put it in one the bottom slots on the 2851 as i'm not sure the usage of those slots.
https://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
From this doc i'm guess the bottem slot is for EVM cards only.
Basically I need to accomplish fitting in:
3 x 4fxs/did cards.
2 x vwic2-2mft-t1 cards.
2 x vic2-4fxo cards.
In a 2851. Is this possible or am I looking at another router?
Correct Answer by paolo bevilacqua about 8 years 3 months ago
For what are you using the vwic2-2mft-t1 ? If for data you could replace it with one HWIC-4T1/E1.
Alternatively I would try to collapse all analog voice on an EVM cards, freeing the WIC slots.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Wed, 03/04/2009 - 12:45
  • Hall of Fame,
    Founding Member
jharris2006 Wed, 03/04/2009 - 13:03
Thanks!
Nothing less expected. A bunch of your posts on other issues have help me along the way as well.
HWIC-4T1/E1 is the best answer. T1's are just for data so it works.
Side-note:
They use 12 ports for fxs/dids so I couldnt collapse into the EVM cards as those only do 8 ports a module. So slot usage would remain the same.
paolo bevilacqua Wed, 03/04/2009 - 13:06
  • Hall of Fame,
    Founding Member
Yes you can further collapse into an EVM if you want, there are daughter modules like 8-FXS, 8-FXO, and even an oddball 7 ports mixed. You need a dedicated patch panel for the EVM but that adds neatness to the installation.
Your appreciation is very welcome and good luck!
