03-04-2009 12:49 PM - edited 03-10-2019 04:22 PM
Hi there
we have two ACS appliances and they send a lot of NetBios broadcasts. Why are they sent (are they needed) and is there any way to disable this?
Thanks in advance and best regards
Dominic
Solved! Go to Solution.
03-05-2009 09:24 AM
if your ACS appliance has version 4.2 there is a bug that identifies this problem, this is not yet fixed I would advise you to subscribe yourself to that bug to receive updates as to when will it be fixed:
CSCsw19289
03-05-2009 09:24 AM
CSCsw19289
03-06-2009 05:08 AM
Hi imartino
thanks a lot for your answer. I will subscribe to the updates.
Best regards
