Historical Reporting Client
Recently we hqave updated to the new IOS 12.4(22) T2 and CUE ver 3.2.  We have enabled historical reporting and as well installed the Historical reporting Client.  When we try to connect we get an error stating "failed to initialize any database connections. Check the log file for error 5066"
Here is the log file
%CHC-LOG_SUBFAC-7-UNK:http://10.1.10.1/histRepWebSrvrComp/histRepClientsServlet?usrid=cisco&pa...
17: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to load XML response from authentication servlet
18: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Successfully loaded XML response from authentication servlet
19: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Attempting to read authentication result from XML response from authentication servlet
20: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Recieved Successful authentication result from XML response from authentication servlet
21: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Apps Server does not impose max connection restriction.
22: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server UID('hr_client') of 'CUE_DATABASE
23: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server SERVER('10.1.10.1') of 'CUE_DATABASE
24: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server DATABASE('hrdb') of 'CUE_DATABASE
25: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-7-UNK:Obtained from Apps Server NODE_ID('') of 'CUE_DATABASE
26: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-3-UNK: Error # 91 ,Description= Object variable or With block variable not set ,LastDllError= 0
27: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-3-UNK:Failed to login user to the apps server since we failed to initialize database connections
28: 03/04/2009 4:35:30 PM %CHC-LOG_SUBFAC-3-UNK:No Database Connections | Failed to initialize any database connections.  Check the log file for error 5066.
29: 03/04/2009 4:35:31 PM %CHC-LOG_SUBFAC-4-UNK:Application Exiting ...
From what i can tell the error is around line 25 to line 27, but I have no idea how to resolve this.  I've tried to edit the hrcConfig.ini but nothing ive tried has resolved this.
Please Help,
Micro Technology
Moderator Tue, 03/10/2009 - 07:11
Thank you for posting the solution to the issue. Please let us know if you have any other questions in the future.
Thank you,
Cisco Moderation Team
Related Content
