Faxing from IP IVR
Mar 4th, 2009
Guys,
customer has RightFax server that is not integrated with exchange. For faxing they are using RightFax client application. when they are sending a fax, client application will create to field in the form:
RFax: John Smith@/FN=number
I am trying to send an email from the IP IVR that has document attached to it.
I configured my email susbsystem with the rightfax address and I am trying to send an email with the attachemnt to the fax server.
If I try to put address in the abovementioned format, email send step will fail because address is not compliant with RFC 822.
Does anybody has any advice.
M
ivillegas Tue, 03/10/2009 - 07:05
  • Silver, 250 points or more
Specify a destination name and fax number in the To: or Cc: box of a new message using this format: [RFAX:Name@/FN=FaxNum]
You must include the opening and closing square brackets.
