Oracle varchar2 not returned as String
Mar 4th, 2009
We have CRA 3.1 and we are trying to intergrate it with oracle 10i. we have a query that returns a row with 5 fields. 3 strings and 2 integers. We that have to put these values in local variables. The interger values are OK but the string values do no appear on CRA. We than tried MS-SQL and all valeus are returned (using the same query). Do you know if CRA 3.1 has any incompatibility with oracle varchar2 datatypes? we also have tried oracle char and varchar datatypes but none worked.
santiago_figuer... Tue, 05/12/2009 - 12:57
Hello can you tell me how you configured the ODBC driver and how you installed the client Oracle. I just have the same scenario.
Thanks.
