PA-MC-8T1 on FlexWan in 6500
Answered Question
I cannot get the PA-MC-8T1 to work on our 6509-NEB. See the flexwan module ok but not the PA, IOS is 12.1(27b) so I am ok there. I am wondering if it is an issue with not being supported by the SUP1A-2GE. Any help would be appreciated.
Correct Answer by Yudong Wu about 8 years 1 month ago
Yes, correct, flexwan is hot swappable, PA might be not. Most time, I just suggest customer to pull out flexwan when replacing PA.
Overall Rating: 5 (1 ratings)
Yudong Wu Wed, 03/04/2009 - 21:10
  • Gold, 750 points or more
In "show diag", did you see PA-MC-8T1?
Show diag below, flexwan is in slot 7, looks like it does see it in Bay 0???
C6509#show diag
Slot 7: Logical_index 14
FlexWan controller
Board is analyzed ipc ready
HW rev 1.3, board revision B0
Serial Number: SAD04320GD6 Part number: 73-3869-07
Slot database information:
Flags: 0x2004 Insertion time: 0x240BAD44C (16:46:01 ago)
Controller Memory Size:
56 MBytes CPU Memory
8 MBytes Packet Memory
64 MBytes Total on Board SDRAM
IOS (tm) cwlc Software (cwpa-DW-M), Version 12.1(27b)E, RELEASE SOFTWARE
(fc2)
PA Bay 0 Information:
Multi-channel (T1) PA, 8 ports
EEPROM format version 1
HW rev 1.00, Board revision A0
Serial number: 23119576 Part number: 73-2488-07
Slot 7: Logical_index 15
FlexWan controller
Flags: 0x2004 Insertion time: 0x240BAC474 (16:46:08 ago)
CWAN Controller Memory Size: Unknown
Yudong Wu Thu, 03/05/2009 - 08:33
But "CWAN Controller Memory Size: Unknown" does not sound right. Can you try to reseat both PA and flexwan? You can try Bay 1 as well.
Yudong Wu Thu, 03/05/2009 - 09:22
flexwan has two slots, we call it bay 0 and bay 1. You can put PA in another slot of flexwan if possible.
Correct Answer
Yudong Wu Thu, 03/05/2009 - 09:25
Yudong Wu Thu, 03/05/2009 - 10:14
Could be.
If you don't mind, you can try to put it back to bay 0 again. If it still has issue, you need to replace flexwan.
Looks like it is still good moved back to bay 0????
C6509#show diag
FlexWan controller
Flags: 0x2004 Insertion time: 0x244CC31B4 (00:13:20 ago)
(fc2)
FlexWan controller
Flags: 0x2004 Insertion time: 0x244CC23C0 (00:13:31 ago)
(fc2)
