NAT issues
Mar 4th, 2009
Hi Cisco,
Our Head Office and remote sites in Sydney is setup as Hub/Spoke network. All Internet traffic via Head Office border router. We are using a point-to-point Ethernet connection from Hub to Spokes and /30 Public IP Address per access link. All public IP is assign from our pool.
We do not want to setup GRE Tunnel or DMVPN for this Hub/Spoke setup as I think it is not neccesary because Remote sites only have one path to the Internet, which is via Head Office.
Behind the Spoke sites is a 10.x.x.x/24 network which hold a Domain Controller server for our team to login too so we can manage their PC via Active Directory.
Below is a sample configuration of each Cisco node and also attached network diagram.
HUB Config:
Cisco IOS Software, 3700 Software (C3725-ADVSECURITYK9-M), Version 12.4(7c), RELEASE SOFTWARE (fc2)
interface FastEthernet0/0
description TRUNK FROM REMOTE 1
bandwidth 102400
no ip address
load-interval 30
speed 100
full-duplex
no mop enabled
no clns route-cache
interface FastEthernet0/0.10
description TO REMOTE 1 -- 4Mbps ETHERNET
bandwidth 4096
encapsulation dot1Q 10
ip address 202.203.204.1 255.255.255.252
no snmp trap link-status
interface FastEthernet0/1
description TRUNK FROM REMOTE 2
bandwidth 102400
no ip address
no ip mroute-cache
load-interval 30
speed 100
full-duplex
no mop enabled
no clns route-cache
interface FastEthernet0/1.20
description TO REMOTE 2 -- 4Mbps ETHERNET
bandwidth 4096
encapsulation dot1Q 20
ip address 202.203.204.5 255.255.255.252
ip route 0.0.0.0 0.0.0.0 name DEFAULT-ROUTE-INTERNET
ip route 10.10.10.0 255.255.255.0 202.203.204.2 name REMOTE_1-INTERNAL-NETWORK
ip route 10.20.20.0 255.255.255.0 202.203.204.6 name REMOTE_2-INTERNAL-NETWORK
REMOTE 1 Config: (Remote 2 config is identical with the appropriate IP Address)
Cisco IOS Software, 3700 Software (C3725-ADVSECURITYK9-M), Version 12.4(7b), RELEASE SOFTWARE (fc2)
description Link to Head Office - 4Mbps Ethernet
bandwidth 4096
ip address 202.203.204.2 255.255.255.252
ip accounting output-packets
ip nbar protocol-discovery
ip nat outside
ip virtual-reassembly
no ip mroute-cache
load-interval 30
speed 100
full-duplex
description TO SWITCH STACK - 3560 SWITCHES
no ip address
no ip mroute-cache
load-interval 30
speed 100
full-duplex
interface FastEthernet0/1.998
description Remote 1 Team Network
encapsulation dot1Q 998
ip address 10.10.10.1 255.255.255.0
ip inspect mktfw in
ip nat inside
no ip mroute-cache
ip route 0.0.0.0 0.0.0.0 202.203.204.1 name DEFAULT-ROUTE-HEAD-OFFICE
ip route 10.0.0.0 255.0.0.0 202.203.204.1 name 10-ADDRESS-RANGES
ip nat pool REMOTE1 202.202.202.1 202.202.202.2 netmask 255.255.255.252
ip nat inside source list NAT_ACL pool REMOTE1 overload
ip access-list extended NAT_ACL
remark DENY NAT FOR REMOTE 1 TEAM ACCESSING 10 NETWORKS
deny ip 10.10.10.0 0.0.0.255 10.0.0.0 0.255.255.255
remark PERMIT IP ACCESS FROM SERVCORP NETWORKS
permit ip 10.10.10.0 0.0.0.255 any
The problem we are currerntly facing is from time, when the DC at Remote 1 needs to connect to DC at Remote 2, it gets NATed on the router close to the source. When this problem occurs, I see 2 NAT entries from the show ip nat translation command which is why communication between the 2 DC goes down for replication.
We have a NAT ACL applied to the NAT pool which should be denying this traffic from 10.10.10.x to 10.20.20.x. 95% of the time the traffic from one DC to the other is working perfect, where the NAT rule denies NATing and uses the static route to send data to the other 10.20.20.x via HUB.
