CM and Cat2950
Mar 4th, 2009
With my understanding, CM uses
portAdditionalOperStatus OID to know the err-disabled port. The link :
indicate that there is not a verion of IOS available for the Catalyst 2950 switches that support this MIB. Is this correct?
Is there any IOS available to support CISCO-STACK-MIB on cat2950?
Is there any other way we can check the cat2950 switchs err-disabled ports using LMS?
Joe Clarke Wed, 03/04/2009 - 19:03
This is correct. Campus Manager uses portAdditionalOperStatus to obtain err-disable status on switch ports.
No, this object is not supported in any 2950 IOS image.
You can use RME's Network Show Commands feature to connect to the switches, and run show commands to give you the accurate port state. For example, you could run "show int status" on these switches, and see which ports are err-disabled.
