naveen_b81 Wed, 03/04/2009 - 22:02
You can connect the DB9 pin of the console cable to your PC and the RJ45 (ethernet linke interface) to the console port of the router or switch.
Then open, Hyperterminal (Start->Programs->Accessories->Communication->Hyperterminal)
Reset to default settings and you should see the configuration window
ohassairi Wed, 03/04/2009 - 22:08
  • Silver, 250 points or more
there is a program in windows called hyperterminal
start/programs/accessories/communications/hyperterminal
give a name, choose a com port, restore default the settings.
normally you should get connected
Joseph W. Doherty Thu, 03/05/2009 - 04:34
As the other posters have noted, if using a Windows PC, Hyperterminal can be used to access the network device's "console".
You will need to insure Hyperterminal is using the correct comm port (the one you've connected the cable to), and insure the comm parameters match your Cisco network device's settings. Parmeters 9600/8/none/1/none will likely work (NB: these might be set if you "press" the Restore Defaults button [as also noted by Ohassairi].)
fjcardenas-1 Thu, 03/05/2009 - 07:28
If you are using windows vista you might not find hyperterminal. Download Putty and it works perfect.
