stateful VPN failover
Mar 4th, 2009
I'm looking the way to get statefull failover with dual Service provider using HSRP 3825 ISR routers. if there is any idea please.
ramesh.karki Thu, 03/05/2009 - 18:23
Well, I got the inside VIP and how it works, but what I have to do if I have already two Service Provider for redundancy.
The main scenario is I have two routers for device failover and two service provider for network redundancy
auraza Fri, 03/06/2009 - 07:24
Ramesh, there is no way to do that with 2 Service Providers, unless you have an Internet router in the front advertising an address space owned by you behind it, and that address space has the two routers running IPSec HA on them.
The best you can do is backup servers in case of ezvpn or a secondary peer, with RRI to take care of routing.
