Pickup fail
Mar 4th, 2009
Hello
I hava a problem with pickup. when I pickup call, has a busy. I check service and setup is correct. Then I solve this case by change number of pickup and assign to DN.
Please help me to verify. What a happen of this problem.
I use callmanager 4.2(3)SR3a.
Thank you for your answer.
mightyking Thu, 03/05/2009 - 07:01
Make sure both phones are part of the same Pickup group. Also make sure both phones CSS contain the partition of the Group Pickup number.
Have a look at this great threat:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1606f
MK
nengkung Fri, 03/06/2009 - 00:13
thank you fot you answer
I setup pickup feature is correct. I use this feature normal and not have a problem. But this week I have a problem.
I check and verify that config is correct. Then I delete pickup number and add new. It works.
Please help.
