Configuring policy-map in 4503 switch
Mar 4th, 2009
Hi, we trying to configure policy-map in 4503 switch and by applying through police we are experiencing packet drop.
config detail:
class-map match-any voice
description voice
match access-group 101
policy-map priortization
class voice
police 768000 bps 1000 byte conform-action transmit exceed-action drop
class class-default
police 7000000 bps 1000 byte conform-action transmit exceed-action drop
Please let us know what is the best method of configuring the same
thanks
royalblues Wed, 03/04/2009 - 22:55
  • Green, 3000 points or more
Which class are you seeing the drops?
Chnage your policy map to something like this
class voice
priority 768
class class-default
The priority command will enable the class for priority queueing and will have an implicit policer as well.
Narayan
gopinathv Wed, 03/04/2009 - 23:00
hi, in this switch i can see only few option in policy-map
cat01(config-pmap-c)#?
QoS policy-map class configuration commands:
no Negate or set default values of a command
police Police traffic matching current class
set Set QoS values
dbl Dynamic buffer limiting
exit Exit from QoS class action configuration mode
trust Set trust value for the class
i dont see the priority or bandwidth option in this Version 12.2(20)EW4 switch.
thanks
