HUM 1.1 - Threshold Mgmt -> Need hysteresis
Mar 4th, 2009
Hi there,
with creating threshold in Threshold-Mgmt the only option is to select a static value for thresholds.
Are there any possibilities to implement a hysteresis for rising and falling thresholds?
Or when will this feature be implemented?
With static values in thresholds this can lead to a lot multiple threshold-violations for one single event.
Thx for any feedback
Lothar
Joe Clarke Wed, 03/04/2009 - 23:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is a feature coming in HUM 1.2 (part of LMS 3.2) called TrendWatch. TrendWatch will allow you to apply more granular rules to templates and thresholds. However, it won't really give you what you want in terms of threshold hysteresis. Unfortunately, the threshold configuration is not changing much in HUM 1.2.
The best you can do to control the threshold generation now is to set the number of violations to a count greater than 1. Of course, this doesn't work like the rising/falling threshold system, but it can help alleviate some event duplication.
As an alternative, depending on the device and MIB objects in which you're interested, you might consider setting up RMON events and alarms in CiscoView's mini-RMON Manager. That ha sthe capability of doing rising/falling thresholds.
