How to configure Auto Busy Redial?
Mar 4th, 2009
My customer need a feature called "Auto Busy Dial" that allows a station user how has placed an outside call to a busy number to have the system redial the number until the call is connected.
I wonder if CME can provides this feature or not?
Rob Huffman Thu, 03/05/2009 - 06:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Huy,
Sadly this feature is not available in CME or CCM. The closest thing in either system is called Callback. This only works for Internal Extensions;
Callback-Requests callback notification when a busy called line becomes free.
Callback Busy Subscriber
This feature allows callers who dial a busy extension number to request a callback from the system when the called number is available. Callers can also request callbacks for extensions that do not answer, and the system will notify them after the called phone is next used.
There can be only one callback request pending against a particular extension number, although a caller can initiate more than one callback to different numbers. If a caller attempts to place a callback request on a number that already has a pending callback request, the caller hears a fast-busy tone. If the called number has call forwarding enabled, the callback request is placed against the final destination number.
No configuration is required for this feature. To display a list of phones that have pending callback requests, use the show ephone-dn callback command.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wpmkr1128179
Hope this helps!
Rob
Hythim Ali El Hadad Thu, 03/05/2009 - 07:30
  • Silver, 250 points or more
In addition to the nice words from Rob,
I need to told that I didn't find the call back feature for externall calls with any other PBX Model
