TACACS problem
Mar 4th, 2009
In Commom Services homepage, Under Security the Authentication mode TACACS is in redcolour. Can you please tell me why the TACACS is in RED colour. Is it coz of any problem? I have attached the screen shot also. Please have a look and provide the solution.
Joe Clarke Thu, 03/05/2009 - 00:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This indicates that there was a problem contacting the TACACS+ server on tcp/49 from the LMS server. When you login to LMS now, you will be using the local LMS authentication database instead of the TACACS+ server.
If you have confirmed that the TACACS+ server is up, and properly servicing AAA requests, have a look at this thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&topicID=.ee71a02&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd25257
akash03lingam Thu, 03/05/2009 - 03:37
I have restarted the Daemon manager. But then also problem with TACACS is still persists. please suggest
Joe Clarke Thu, 03/05/2009 - 10:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Then there must be a communication problem. Double-check your TACACS+ module configuration under Common Services > Server > Security > AAA Mode Setup. Make sure the TACACS+ secret key is correct with what your server has configured, and again, make sure tcp/49 is reachable from the LMS server to the TACACS+ server.
