wlc and ssid
Answered Question
Mar 5th, 2009
hi, all!
i try to find an answer if wlc can advertise not all ssid to the lap's. how can i setup this feature?
for example - i have 10 LAPs over the building and 5 SSID's.
i need to advertise only 3 SSID at the 1 floor and all of them at the second floor.
is it possible?
ps sorry for my bad english ))
Correct Answer by jigsaw2026 about 8 years 4 months ago
Hi Vadik,
Yes it's possible - in version 4 you would use WLAN override. Basically in the radio config of each AP you can select WLAN override, and then check the WLANs that you want to advertise.
In version 5 you would use AP groups.
I've found this quite helpful:
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
J
Overall Rating: 5 (1 ratings)
Correct Answer
jigsaw2026 Thu, 03/05/2009 - 02:34
Hi Vadik,
J
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
