layer 3 switch question
Answered Question
Mar 5th, 2009
  • Bronze, 100 points or more
Hi all,
I seem to recall, in this forum a little while ago a topic that I think was about the capability to change the cpu percentages and/or queues on a layer 3 switch or something..??
If memory serves, this capability is in a layer 3 switch and can be changed if the switch was only going to be used as a layer 2 device..
Does anyone remember that or am I dreaming?
I'm hoping someone can jog my memory, or even better still, post a link to a document about it.
Thanking you in advance!!
Brad
Correct Answer by JamesLuther about 8 years 4 months ago
Are you refering to the SDM templates? On some of the smaller switches (ie 3750, 3560) you can apply a template.
This allocates more system resources towards layer 2 or layer 3 operations depending on what you're using your switch for
Just search for "SDM templates" on cisco.com or chesk this
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_20_se/configuration/guide/swsdm.html
Overall Rating: 5 (1 ratings)
Correct Answer
JamesLuther Thu, 03/05/2009 - 00:35
  • Silver, 250 points or more
bmcginn Thu, 03/05/2009 - 01:58
Mate, that is exactly what I was after.. thanks a lot!!!
Brad
