ACE Loadbalance on same interface
Mar 5th, 2009
Hi Guys,
I am tryign to deploy a solution where by i have 5 servers sat behind the ACE in a routed fashion. There are static nats to these servers for management.
3 of the servers are standard web farm.
Now these 3 servers need to speak to a VIP setup on the ACE to loadblance the traffic between the remaining 2 servers for CMS. Is this possible with them all on the same vlan?? I have tried setting up a VIP server vlan side (no joy) Tried connecting to a vip on the Client side from the servers (no joy).
Any help would be much appreciated.
Config to follow
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 03/05/2009 - 02:59
  • Cisco Employee,
you need to configure client nat when doing this. Otherwise the server response will directly go the client_server which will reject it because not coming from the vip.
Gilles.
scott-goodwin Mon, 03/09/2009 - 00:35
Hi Giles,
The config is attached, as you can see I have incoming nats for management of the servers, hence I initially pointed the servers to a vip on the 250.x side of the ace, however this doesnot work.
As can be seen I also set up a vip on the 240.x side for the DIIOP service.. but this doesn't function either???
Scott
scott-goodwin Tue, 03/10/2009 - 01:00
How can i setn up client Nat, when i Am already natting for management purposes??
Scott
Anonymous (not verified) Tue, 04/28/2009 - 08:02
You can try this:
-. Create the VIP in the server side.
-. Then Nat all traffic hitting that VIP. You can do that with the command "nat dynamic" inside of the Policy map.
Example:
policy-map multi-match L3L4_LOADB
class CLASS_MAP
loadbalance vip inservice
loadbalance policy L7_LOADB
loadbalance vip icmp-reply active
loadbalance vip advertise active
nat dynamic 1 vlan 118
interface vlan 118
bridge-group 118
no icmp-guard
access-group input ALL
access-group output ALL
nat-pool 1 10.0.0.3 10.0.0.3 netmask 255.255.255.255 pat
no shutdown
