Trouble archiving Cisco MDS 9124
Answered Question
Mar 5th, 2009
We are having trouble archiving our SAN switch config.
We are using LMS 3.0, is there something I need to change in the configuration?
Correct Answer by Joe Clarke about 8 years 3 weeks ago
This device is supported in RME 4.1.1 with MDS package version 5.1. Make sure you have the MDS package properly loaded under Common Services > Software Center > Device Update.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 03/05/2009 - 10:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What trouble are you seeing exactly? What errors do you see when trying to run a Sync Archive job against these devices?
uwic2 Fri, 03/06/2009 - 01:40
Hi thanks for your response.
The error message I am getting is:-
CM0056 Config fetch failed for llswl1san1.internal.uwic.ac.uk Cause: CM0204 Could not create DeviceContext for 1230 Cause: CM0206 Could not get the config transport implementation for 192.168.199.21 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Jamie
Joe Clarke Fri, 03/06/2009 - 08:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This points to a missing device package within RME. What version of RME do you have? What is the sysObjectID of this MDS?
uwic2 Mon, 03/09/2009 - 01:23
Thanks for your help with this.
The version of RME is 4.1.1 the ObjectID is .1.3.6.1.4.1.9.12.3.1.3.587
Jamie
Correct Answer
Joe Clarke Mon, 03/09/2009 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
uwic2 Thu, 03/12/2009 - 01:44
That worked, thank you ever so much.
Jamie
