SRST / MGCP Failover Problem
Mar 5th, 2009
Hi all
I am simulating a failure on our UC 6 system, and the IP Phones have successfully gone into CM Fallback Service Operating mode. However, when I dial a number, it only accepts 4 digits and then tries to set up the call.
Below is the config:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.28.3.254 port 2000
max-ephones 300
max-dn 300
dialplan-pattern 1 011256.... extension-length 4
call-forward busy 9000
call-forward noan 9000 timeout 15
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384
Is the dialplan-pattern config correct?
On the CUCM phones are configured with 4 digit extensions and have the 011256XXXX masked.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Thu, 03/05/2009 - 05:05
the dial plan dose not effect
this problem should be from a dial-peer
check your dial-peer
it sounds you have a dial peer that has destination pattren as 4 digits and get matched first
if didnt solved post you dial peers
good luck
if helpful Rate
shaunswales Fri, 03/06/2009 - 00:20
dial-peer voice 1 pots
service mgcpapp
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
service mgcpapp
direct-inward-dial
port 0/1/0:15
dial-peer voice 3 pots
service mgcpapp
direct-inward-dial
dial-peer voice 4 pots
service mgcpapp
destination-pattern 0T
direct-inward-dial
port 0/1/0:15
dial-peer voice 5 pots
service mgcpapp
direct-inward-dial
dial-peer voice 6 pots
service mgcpapp
direct-inward-dial
dial-peer voice 10 voip
destination-pattern 0...
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
voice-class codec 1
session target ipv4:172.21.34.162
dial-peer voice 11 voip
preference 1
voice-class codec 1
session target ipv4:172.21.34.163
dial-peer voice 510 pots
service ccm
incoming called-number 0505
direct-inward-dial
dial-peer voice 511 voip
destination-pattern 0505
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1510 voip
service ccm
codec g711ulaw
no vad
Marwan ALshawi Fri, 03/06/2009 - 01:34
here as i told you the bellow ones has 4 digits and get mastched befor the one that has 0T
voice-class codec 1
preference 1
voice-class codec 1
chant it to sothing more spicific for example
destination-pattern 05..
voice-class codec 1
preference 1
voice-class codec 1
one more thing now the call in SRST mode when made to outside lets say 0 and the number will takre about 10 second to make the call this si the defualt
if u wanna reduce it under th call-manager-fallback
timeout interdigit [number in seconds]
good luck
if helpful Rate
