Read IPS IP Log file
Mar 5th, 2009
Hello, I have a IPS-SSM-20 (6.2.1) and I'm using IME 6.2 to manage it. On IME-> Configuration->Time Based-> IP Logging is possible to capture a particular IP traffic and download the file. Does someone know, once downloaded, how to read it ?
rhermes Thu, 03/05/2009 - 08:28
While I don't specifically remember "time based" capture, I have performed captures based on a source or destination IP address on the AIP-SSM modules. They are saved on the module in pcap format. This is a standard packet capture format used by any packet sniffer, such as Wireshark (free) http://www.wireshark.org/
Download the pcap and open with Wireshark. Make sure you try out the "follow TCP stream" option in Wireshark, it's great for following a single session.
