03-05-2009 05:35 AM - edited 03-15-2019 04:38 PM
hi, i am trying to make a sip trunk between a cme 7.0 and ccm 4.1, the ccm 4.1 already has a sip trunk working to an OCS, so i created a new one, but i had to change the ccm's incoming port to 5061, to create it.....!!so i want to know, how can i configure the cme to point the sip trunk (dial-peer sip), to the ccm's 5061 port.
Solved! Go to Solution.
03-05-2009 07:15 AM
This command will also change the port used to send SIP traffic.
Hope this helps.
Brandon
03-05-2009 06:05 AM
You can change the SIP port on the CME with the following commands:
sip-ua
listen-port
Be aware that this is a global configuration. All SIP dial peers will use the new port for SIP communications.
Hope this helps.
Brandon
03-05-2009 07:13 AM
hi, but i dont need to change the listen port on the ccme, i need to send the ccme trafic to the port 5061.....because the ccm has configured to listen this port..... in resume, i need to send the SIP outgoing traffic from the ccme using the 5061 port
03-05-2009 07:15 AM
Hope this helps.
Brandon
