2851 how many nat translations support
Mar 5th, 2009
Hi:
I have a 2851 and i just want to know how many ip nat translations can this router support. Currently i have a issue with some ip addresses making a several number of ip nat translations, and the cpu utilization get up to 99%.
quevedo_lopez Thu, 03/05/2009 - 06:06
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(20)YA2, RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 22-Jan-09 15:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
2851-ROUTER uptime is 3 hours, 39 minutes
System returned to ROM by reload at 07:26:09 CENTRAL Thu Mar 5 2009
System image file is "flash:/c2800nm-adventerprisek9-mz.124-20.YA2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2851 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1227A3KF
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2103
quevedo_lopez Fri, 03/06/2009 - 04:08
Like i said before:
179 3453980 58910 58631 93.30% 92.12% 92.50% 0 IP NAT Ager
