Call Manager 4.2.3(sr1) with 7970 url too long
Answered Question
Mar 5th, 2009
I have a problem with a 7970 phone registered to a CCM 4.2.(3)sr1. When I try to change the settings on the phone and update the config, I get the failure `url too long'. In some earlier surches I found in bug <CSCsg22098> to upgrade to version 4.2(3)ES10. Is that the solution and how can I get it?
Thanks in advance.
Attached youll find a screen shot
Correct Answer by Rob Huffman about 8 years 2 weeks ago
Hi Erich,
Just to add a note to the good tips from my friend Java (Happy Friday Java ...+5)
From the page the Java linked;
Go to;
Software Delivery System
Voice and Unified Communications is now available for download through the new delivery system.
To access Voice Software downloads, click here.
Voice and Unified Communications > IP Telephony > Call Control > Cisco Unified CallManager Version 4.2 > Unified Communications Manager Updates > 4.2(3)SR4b
Here are the Release Notes;
Cisco Unified CallManager 4.2(3) Service Release 4b
http://www.cisco.com/web/software/282074295/23506/ciscocm.4-2-3-sr4b-Readme.pdf
Hope this helps!
Rob
Overall Rating: 4.3 (3 ratings)
Jaime Valencia Thu, 03/05/2009 - 12:05
  • Cisco Employee,
  • Hall of Fame,
    2011
install the latest SR to fix this
java
if this helps, please rate
ezy Fri, 03/06/2009 - 01:43
Thanks for the reply, but where to find this release? I checked the download DB of Cisco but didnt find!? In the past it something like ciscocm.4-2-3-sr1.exe for example.
Correct Answer
Rob Huffman Fri, 03/06/2009 - 06:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Erich,
Go to;
Hope this helps!
Rob
