NVRAM inaccessible - Strange Behavior
Mar 5th, 2009
  • Blue, 1500 points or more
Has anyone seen this before? This is definitely a first for me.
Here is the problem:
If I telnet to a router and execute the "sh start" command and then try to execute it again using another remote telnet session, the startup config will not open up.
The error message I get is the following:
%Error opening nvram:/startup-config (Device or resource busy)
The way to eliminate this message is to terminate the original telnet session OR return to the command prompt in the original telnet window. In other words, when executing the "sh start" command, do not leave it where there is still "-more-" configuration to view. Type any letter to break it and get back to the command prompt. If you do that, the "sh start" command will work from the second telnet session.
I think this is weird behavior and I have never seen it before. Cisco does have a webpage that dicusses it, but it doesnt elaborate on whether this is a bug or normal behavior or why this happens. They also dont tell you about returning to the command prompt on the initial session to get it to work on the second one. All they tell you to do is terminate the original session.
Any ideas?
Overall Rating: 4.7 (4 ratings)
Jon Marshall Thu, 03/05/2009 - 07:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Victor
Long time ...
I have seen this many times and the only way i have of working around it is as you say to either terminate the session or more often to just make sure you haven't left it at the --More-- prompt.
Not a great deal of help i know.
Jon
guruprasadr Thu, 03/05/2009 - 07:22
  • Gold, 750 points or more
HI Victor, [Pls RATE if HELPS]
When there is simultaneous access to a router's NVRAM, you might encounter these two errors:
While you display the contents of the NVRAM with the show startup-config command:
Router#show startup-config
Using 5524 out of 129016 bytes
While you save a configuration to the NVRAM with the copy running-config startup-config command:
Router#copy running-config startup-config
Destination filename [startup-config]?
startup-config file open failed (Device or resource busy)
Solution:
clear the line the other user(s) is (are) connected on and free the NVRAM, issue the clear line command.
Note: The "*" next to line No# vty No# indicates the line used in this session.If there are more multiple users, clear all of them, except for the line with the "*".
Try accessing NVRAM now !!
Hope I am Informative.
Best Regards,
Guru Prasad R
lamav Thu, 03/05/2009 - 07:32
Jon, thanks. What you say does help because it lets me know that I have a grasp on whats going on and how to handle it.
Now mosey on over to the other thread Im about to start regarding troubleshooting ethernet interfaces. :-)
Guru:
Thanks for your input. I know where you got all that information: its from the webpage I have been reading on Cisco's website regarding this problem. Its the one I reference in my original post. Appreciate your efforts...
Victor
Giuseppe Larosa Thu, 03/05/2009 - 08:08
  • Hall of Fame,
    Founding Member
Hello Victor,
this is a common problem.
you can see nvram: as a file system and the startup-config as a file.
During sh startup-config
the file is opened for reading
we can say that the nvram: filesystem doesn't support concurrent reading.
If I remember correctly some Lan switches allow to enable concurrent access to NVRAM
Edit:
I tried what is possible with switches is concurrent access to config mode with
no configuration mode exclusive
Hope to help
Giuseppe
lamav Thu, 03/05/2009 - 08:19
Thanks, G.
