Controlling bandwidth on a DMVPN network
Mar 5th, 2009
Hi All,
I have a DMVPN network between a central site (HUB) and approximately 90 remote sites (spokes).
I need to control the bandwidth that each customer gets through the network... my question is.... can I use QoS or should I use another method or perhaps a dedicated device to control the traffic? What is the best recommendation?
Thank you all!
JHaynes4 Thu, 03/05/2009 - 10:30
You could try policing traffic at each remote site and tailor it to your needs.
fedecotof Thu, 03/05/2009 - 11:02
Would Policing really help if the DMVPN goes over the Internet? I mean, I can control the amount of traffic that each remote site sends,or the central site, but then there's no guarantees on the Internet correct?
Please point me in the right direction.
Thank you!
