ip sla reaction-configuration question
Mar 5th, 2009
My goal is to have "track 111" go from up to down in the event of three successive ping losses. I wish the configuration guide had some more simple examples. Anyhow - when I run "show ip sla reaction-trig 1" IOS responds "Reaction trigger not configured" I don't understand why not. And I'm not clear if my end-goal of track going down on 3 losses is met. Any ip sla masters on here??
track 111 rtr 1
ip sla 1
frequency 30
ip sla reaction-configuration 1 react rtt threshold-type consecutive 3 action-type trapAndTrigger
ip sla schedule 1 life forever start-time now
Cisco2811ILG#sho ip sla reaction-configuration
Entry number: 1
Index: 1
Reaction: rtt
Threshold Type: Consecutive
Rising (milliseconds): 5000
Falling (milliseconds): 3000
Threshold CountX: 3
Threshold CountY: 5
Action Type: Trap and trigger
Cisco2811ILG#sho ip sla reaction-trigger
Entry number: 1
Cisco2811ILG#sho ip sla statistics
Round Trip Time (RTT) for Index 1
Latest RTT: 16 milliseconds
Latest operation start time: *13:26:31.017 EST Thu Mar 5 2009
Latest operation return code: OK
Number of successes: 28
Number of failures: 0
Operation time to live: Forever
Overall Rating: 4 (1 ratings)
adamclarkuk_2 Thu, 03/05/2009 - 11:46
Change your react from rtt to timeout
I have simplfied the config a bit from yours so don't copy it (my timers are very low), but mine works
ip sla monitor 1
type echo protocol ipIcmpEcho
timeout 1
frequency 3
ip sla monitor reaction-configuration 1 react timeout
ip sla monitor schedule 1 life forever start-time now
Router#sh ip sla monitor statistics
Round trip time (RTT) Index 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *19:46:33.155 UTC Thu Mar 5 2009
Latest operation return code: Timeout
Number of successes: 1
Number of failures: 20
Router#sh ip sla monitor reaction-configuration
Entry number: 1
Reaction: timeout
Threshold Type: Never
Threshold Count: 5
Threshold Count2: 5
Action Type: None
mmedwid Thu, 03/05/2009 - 11:54
Thank-you. So in your example it appears that an ICMP timeout is defined as 1 second with no reply and then monitor operation runs with a frequency of every 3 seconds. And your reaction config is saying if there are 5 timeouts then then fail. Correct?
adamclarkuk_2 Thu, 03/05/2009 - 12:31
It's 1 ms with no reply.
I think your issue is down to the fact that you where using round trip times rather than timeout (react rtt).
I am allowing 5 timeouts before alerting ( the default), you can amend this with threshold-type .
