T1 Card installation in Cisco 2821
valides007
I'm installing a new T1 card (HWIC-1CE1T1-PRI) to a Cisco IP-PBX 2821 (CME running on it).
I did install it to HWIC 0 slot(have nothing on HWIC 1, 2 or 3).
It doesn't seem the cisco 2821 is recognizing it. When i do show int, i only see gi0/0 & gi0/1.
Do i need to pass some commands to make the router recognize the card?
I can't pass controller t1 command..
12 Replies 12
mightyking
Level 6
Level 6
What the output of the "show diag" command shows?
Do you have any DSP module installed? Sometimes without the DSP (PVDM) modules, the T1 card won't show up in the system config.
MK
As i know there is no DSP module installed. How can you tell if there is DSP module installed?
An if there is no one, what do suggest for solution?
Again, "show diag" command will tell you the detail about the installed hardwares. Post the output of the follwoing command:
router# show diag
MK
here what i got when i did "show diag":
IP-PBX2#show diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12115GFD
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080320
Chassis Serial Number : FTX1214A2BU
Chassis MAC Address : 001f.ca0a.f2c0
MAC Address block size : 32
CLEI Code : COM7M00ARA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-05
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 31 31 35 47 46 44 40
0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 03 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 66 C0 C2 8B 46 54 58 31 32 31 34
0x40: 41 32 42 55 C3 06 00 1F CA 0A F2 C0 43 00 20 C6
0x50: 8A 43 4F 4D 37 4D 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8539-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC12045367
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : V01
0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 42 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 30 34
0x20: 35 33 36 37 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 0.0
Top Assy. Part Number : 800-27135-02
Part Number : 73-10362-05
Board Revision : C0
Fab Version : 03
PCB Serial Number : FOC12525BDV
RMA History : 00
Product (FRU) Number : HWIC-1CE1T1-PRI
CLEI Code : COUIAKJCAA
0x00: 04 FF 40 05 29 41 00 00 C0 46 03 20 00 69 FF 02
0x10: 82 49 28 7A 05 42 43 30 88 00 00 00 00 02 03 C1
0x20: 8B 46 4F 43 31 32 35 32 35 42 44 56 03 00 81 00
0x30: 00 00 00 04 00 89 56 30 31 20 CB 8F 48 57 49 43
I see you have DSPs but your T1 is not detected. Can you post the output of the "show version"?
As paolo mentionned, you need to upgrade the IOS to the latest.
MK
here is sh version:
Here is sh version:
IP-PBX2#show version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(9)T7, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 16:35 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
IP-PBX2 uptime is 3 hours, 46 minutes
System restarted at 08:50:45 east Fri Mar 6 2009
System image file is "flash:c2800nm-spservicesk9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FTX1214A2BU
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
If i need to upgrade the IOS, does this interfer with my current configuration? and please could you provide me with the steps to do that?
Than you
paolo bevilacqua
You need a very recent IOS for the card to be recognized.
Also configure, card type T1 0.
Paolo,
version 12.4 shouldn't be enough for the card to be recognized?
12.4 should be more than enough to detect the T1 card. Followings are the latest versions for your router. The first is an Early Deployment(ED)and the second one is the Maintenance Deployment (MD). I recommand the MD version. If this does not help, you may want to open a TAC case with Cisco.
12.4(20)YA2
c2800nm-spservicesk9-mz.124-20.YA2
12.4(23)
c2800nm-spservicesk9-mz.124-23
#config t
card type t1 0 0
then check
# show controllers t1
Here's the link but I don't understand why it doesn't show any of them.
http://tools.cisco.com/Support/Fusion/FusionHCHWCompatibleSW.do?mySession=6564971&myStep=10&OperatingSystem=CISCO+IOS+SYSTEM+SOFTWARE&FeatureSet=SPSK9-SPSK9+FEAT+SET+FACTORY+UPG+FOR+BUNDLES&FeatureSetDesc=SPSK9-SPSK9+FEAT+SET+FACTORY+UPG+FOR+BUNDLES&...
Does the output of the "show running config" shows the command Eldho posted?
card type t1 0 0
router# conf t
router# card type t1 0 0
