'show resource usage' - ACE
Mar 5th, 2009
Could you please explain the difference between conc-connections, proxy-connections, connection-rate and ssl-connections rate values on 'show resource usage' output.
Thanks.
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Thu, 03/05/2009 - 19:02
  • Blue, 1500 points or more
My understanding is
Concurrent Connections (Max 4M/Ace module) : Concurrent Layer 4 (through the box traffic) connections.
Proxy Connections : Concurrent Layer 7 connections (Where ACE act as proxy for servers)
Connection Rate (Max 348K/sec): rate at which new connection are made per second
SSL-Connection rate: counter for SSL Transactions Per Second. Its maximum value depends on the license installed.
ACE/Admin# sh license status
Licensed Feature Count
SSL transactions per second 20000 <--
Syed
cisco_lite Thu, 03/05/2009 - 23:19
Thanks.
Does SSL-Connection rate includes one connection to mean - user accessing https for the first time, or every click to a web page over https during a user session.
Syed Iftekhar Ahmed Fri, 03/06/2009 - 01:44
Its SSL handshakes not the encrypted traffic.
Syed Iftekhar Ahmed
