UCCX supervisor on UCCX server
Mar 5th, 2009
Is there any reason why I wouldn't want to install the UCCX supervisor and agent on the UCCX server it's self?
Jonathan Schulenberg Mon, 03/09/2009 - 16:47
I wouldn't recommend it; the Calabrio software components are extremely touchy. It will be installing files into the same directories and registry hives as the server-side components of Calabrio (CAD/CSD/CDA) exist. If one of those registry or files gets overwritten, you may have to rebuild the server. There's a reason they're not installed by default.
