How to use 3750 L3 Switches to do NAT?
Answered Question
Mar 5th, 2009
I would like to know how to use a Cisco 3750 L3 switch to do NAT with?
Eddy
Correct Answer by Edison Ortiz about 8 years 3 months ago
NAT is not supported on those switches.
The only switch to support NAT is the 6500 Series switch.
For NAT purposes, I recommend getting a regular router.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 03/05/2009 - 13:17
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
