cant use rommon mode
Mar 5th, 2009
When I boot my cisco 2620xm it show wierd characters and wont let me do anything. First this was cuased by a power failure when hte router was upgrading. Second I have used the jumpers to reset the console speed with no luck. finally i have removed all modules to see if they were the problem but its no use. How do I fix this router? Its used in a classrooms lab setup.
Giuseppe Larosa Fri, 03/06/2009 - 00:05
Hello Harry,
a C2620xm should have a software based config-register.
try to connect to the console using different speeds until you see readable output
Hope to help
Leo Laohoo Fri, 03/06/2009 - 16:05
You will have to patiently try out every speed there is on the console terminal. No choice.
