7609 IOS Upgrade Problem
wasiimcisco
I have cisco 7609 with two SUP-720, WISM, and ethernet modules. Currently I have IOS s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SRA5,
Because this IOS is not detecting the WISM. I am trying the IOS s72033-adventerprisek9_wan-mz.122-18.SXF15 that i have successfully installed in 6513 catalyst which also include the WISM. But now same IOS for 7609 is not working for me.
I followed the below mention steps.
copy ftp: disk0:
Address or name of remote host [192.168.1.11]?
Source filename [s72033-adventerprisek9_wan-mz.122-18.SXF15.bin]?
Destination filename [s72033-adventerprisek9_wan-mz.122-18.SXF15.bin]?
Accessing ftp://192.168.1.11/s72033-adventerprisek9_wan-mz.122-18.SXF15.bin...
Loading s72033-adventerprisek9_wan-mz.122-18.SXF15.bin !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 63477880/4096 bytes]
copy disk0:s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin slavedisk0
boot system flash disk0:s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin
but no luck. The Router 7609 goes to mointor mode after this.
When i verify the IOS it gave me following error
ATCT-BD-ULV02-7609-01#verify di
7609-01#$0:s72033-adventerprisek9_wan-mz.122-18.SXF15.bin
%Filesystem does not support verify operations
Verifying file integrity of disk0:s72033-adventerprisek9_wan-mz.122-18.SXF15.bin
%WARNING: Signature not found in file disk0:s72033-adventerprisek9_wan-mz.122-18.SXF15.bin.
00:18:34: %SIGNATURE-4-NOT_PRESENT: %WARNING: Signature not found in file disk0:s72033-adventerprisek9_wan-mz.122-18.SXF15.bin.
and even with old image i m not able to write configuration on standby. I m gettin following error.
00:09:34: %PCMCIAFS-SP-5-DFS_CLOSE_ERR: Error during close of the file s72033-adventerprisek9_wan-mz.122-18.SXF15.bin. Failed to flush the remaining file data.
*** Illegal Opcode Exception ***
PC = 0x8010dce0, Cause = 0x28, Status Reg = 0x30409003
00:03:32: %PFREDUN-SP-4-BOOTSTRING_INVALID: The bootfile slavesupboot-disk:/s72033-advipservicesk9_wan-mz.122-33.SRA5.bin is not present in standby
00:03:34: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router. [OK]
Please let me what i m missing and which IOS image required for 7609.
Please also let me know that the steps i used for upgrade are right or not.
wasiimcisco
can anybody help me out.
Leo Laohoo
You copied a file called "s72033-adventerprisek9_wan-mz.122-18.SXF15.bin" from your FTP to Disk0 without a problem.
But you tried to copy "s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin" from Disk0 to SlaveDisk0. Do you have "s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin" in Disk0?
Yasir Ashfaque
type show disk0: and slavedisk0: or dir disk0: and see if same image is there on both disks, also from rommon try to run the image directly by boot command.. see if it helps
