lindborg Thu, 03/05/2009 - 14:11
  • Cisco Employee,
It's not designed to go past 10 - you might be able to continue adding via a direct DB edit but I'm willing to bet the back end DOH code and/or the admin/conversation code will be written to assume only 10 max.
What are you trying to do that you need more than 10 alternate extensions on a single user account?
MikeTomasko Thu, 03/05/2009 - 14:18
  • Bronze, 100 points or more
We have an auto attendant setup in CCM where 5 users have 4 line appearances. So that's 20 different DIDs that could be sent to Unity. I was thinking of using a routing rule to do it or increasing the busy trigger for the first line appearance to 4 instead of 4 different lines. Just wanted to see if there was a hidden hack in Unity.
Thanks for the quick response!
Christopher McAlpin Thu, 03/05/2009 - 14:25
  • Cisco Employee,
In addition to a subscribers primary extension, an administrator can define an additional 9 alternate extensions in the SA.
If a subscribers COS allows, the subscriber can define an additional 5 more alternate extensions in the Cisco Personal Communications Assistant (CPCA).
So this would give you the possibility of a total of 15 extensions per subscriber.
kking2008 Tue, 03/17/2009 - 13:55
I don't suppose that there are allowed wildcards for Alternate Extensions are there?
Christopher McAlpin Thu, 03/05/2009 - 20:14
  • Cisco Employee,
I am not sure what your application or design is, but don't forget that Unity has an Extension Remapping Feature.
See unrelated post where I talk a little bit about Extension Remapping.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&type=Subscriptions&loc=.2cd254ac/4&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications
