VPN3000 concentrator logging client versions
Mar 5th, 2009
Just rolled out a client upgrade. Is there a way for the vpn 3000 concentrator to log the versions of the clients that are logging in so I can make sure everyone is upgraded?
ggilbert Fri, 03/06/2009 - 06:50
  • Cisco Employee,
IKEDBG with a severity of 1-9 should tell you the client type and the version they are logging in as.
Client Type: WinNT
Client Application Version: 5.0.04.0300
Also, you can look at "Administration| Administer Sessions" which will give you the client version also.
Let me know is this is what you are looking for.
Gilbert
