Unity 7 no message delivered
Mar 5th, 2009
Hi, I have a strange issue. If I am OnNet with a cisco phone I can leave a message and get the message/inbox and mwi no problem. If I call from the PSTN I here the mailbox recording, go to leave a message and I get nothing. Its like unity is not getting a audo path. I am running a mgcp gateway with dtmf enable mode out of band. Any ideas??
Jaime Valencia Thu, 03/05/2009 - 16:18
  • Cisco Employee,
  • Hall of Fame,
    2011
any errors in the app log on unity?
check you have routing between GW and unity for the RTP
so, you do get a message? but it's blank? or you don't get any message? i'm not sure which one is it
java
if this helps, please rate
rywalker Thu, 03/05/2009 - 17:02
We were not getting DTMF inbound from the PBX.
The solution was to modify the default values of the advanced ccm
service parameters
* ASN.1 ROSE OID Encoding*
was changed to ISO from its default on Cisco of "use local value"
* QSIG Variant
was changed to ECMA from its default value of ISO.
Problem resolved by doing the above
