EZVPN - IP POOL
Mar 5th, 2009
I configured ezvpn on router to provide connectivity to remote user. I defined pool range 172.16.100.1-20 and enable split tunneling. Remote site (from where users are dialing) is having two local networks there i.e. 192.168.1.0/24 (users network), 172.16.1.0/24 (server farm) Now i am facing problem when user connect vpn, he can ping central IPs and its192.168.1.0/24 network but unable to access 172.16.1.0/24 network there. when i see users PC routing table (route print) after connecting VPN, all traffic for 172.16.0.0 255.255.0.0 is going through VPN.
Central Site (10.x.x.x)---------------ezvpn (172.16.100.1-20)-------------------RemoteSite (users network 192.168.1.0/24, server network 172.16.1.0/24)
If i changes pool range from 172.16.100.1-20 (class B ) to 192.168.100.1-20 (class C), it start working fine
Any way to solve this issue..
Best Regards
ggilbert Fri, 03/06/2009 - 06:42
  • Cisco Employee,
On the router, you cant set a network mask for the pool - unfortunately. So, it will use the default mask according to the pool range you have set.
Your analysis is correct. The option would be to change the pool to a different network.
Hope this helps.
Cheers,
Gilbert
