Jonathan Schulenberg Fri, 03/06/2009 - 07:12
  • Cisco Designated VIP,
    2017 IP Telephony
I've installed UCM 6.1(2), 7.0(1), and UCCX 7.0(1)SR1 in VMware ESX 3.5. All of them work but remember they are NOT supported by Cisco and are for lab use only.
lonenomad Tue, 03/10/2009 - 22:52
Hi J
What is your specs of your hardware?
SP
Tony Knight Wed, 03/11/2009 - 14:15
I am running on a Toshiba M9 with dual 2.1ghz, 4gb memory, 150gb hdd. I have Windows server 2003 r2 as an os with VMware workstation as the VM server. I have Cucm 6.1 loaded with CCX 7. This al loads ok!
My problem occurs when I try an login as an agent from XP which I have tested as a VMware app or as a standalone pc. The agent is configured in Cucm, is recognised by CCX as an agent but presents an error of "ID does not exist" when trying to loggin via the agent.
Any help will be great!
Tony
recep.sefer Sun, 05/10/2009 - 12:03
Which version VMware you are using?
Could you give me little information abouth steps of installing
THANKS
recep.sefer Mon, 05/11/2009 - 09:06
Thanks for your reply.
Are you using special hardware (MCS.., HP, IBM)?
Can I use any hardware on vmWare?
Tony Knight Mon, 05/11/2009 - 13:14
Eventually, I got my VMware environment working on aToshiba M9 with4GB of memory.
recep.sefer Tue, 05/12/2009 - 00:07
Does it to be Toshiba M9
Or any PC-Notebook does the same?
Tony Knight Tue, 05/12/2009 - 08:13
Have not tried on other hardware, but would imagine that any hardware would be the same.
