Cisco and Avaya H.323 intergration
Mar 5th, 2009
Hi, all
Now I have some troubles in integrating cisco and Avaya devices. we have created the h.323 trunk between cm5.1 and avaya device, and on avaya if I use routing to transfer the call to the CM5.1 through h.323 trunk there is no problem. but because some number plan problems, now on avaya we need use the way which capture the trunk first and send the digit one by one on the h.323 trunk to CM5.1, in this situation our cm5.1 can't accept the call session.
For example, we need dial *1234 on avaya to call the cisco ip phone through H.323, the action is that avaya send the number one by one. But CM5.1 can't accept the call.
So my question is that can CM5.1 accept the digit one by one not all digits one time on the h.323 gateway?
Thanks!
Kirin
Nicholas Matthews Thu, 03/05/2009 - 19:42
Hi Kirin,
I think this is the service parameter you're looking for:
Overlap Receiving Flag for H323 = True
hth,
nick
qilin zhang Thu, 03/05/2009 - 21:28
Hi Nick,
Thanks for ur help.
I will try to change the parameter and test the call. I want to know what is the parameter used for?
Nicholas Matthews Fri, 03/06/2009 - 05:22
You can click on the service parameter and the help menu should give you a helpful description.
Overlap receiving is the ability to receive one digit at a time, in short words.
-nick
