Scheduled admin script failed to run
eric.neoh
Hi all.
Am wondering if anyone encountered the problem whereby the scheduled icm admin script didn't run at the scheduled time?
The admin script was scheduled to execute at 7am every morning and it has been running fine for quite a while. It only failed to run recently.
Anyone has any idea what could be the root cause n hw do we resolve it?
Thanks & regards,
Eric
8 Replies 8
daljeetsingh1_2
Level 3
Level 3
Hi Eric, Did you get solution to this issue? we are also hitting the same thing. We are on IPCC E 7.2.4
Though scheduling worked everytime well in the past.. but its not working this time around.
Any clues??
-Daljeet
Were there any changes made to your admin script at all? Maybe adding a new user variable? Check the the router log for that time frame and see if it points you in any direction.
david
Yes, Call center timing got changed, so we changed the script under scheduler and saved it, the new timings are showing up when we goto scheduler tab. but when we call at the main script its taking old timing. we will see router logs to see if we find something..
Daljeet
Can you create a new simple admin script and schedule to run? I'm curios to know if it's just this one script or all admin scripts are affected.
david
Tomorrow we have plans to goto site, will try to do this as well.
Till now i was relying on customer inputs, which may be false :)
Thanks, Daljeet
Customer himself tried changing time and he changed the script as well and had configured main script under after hours as well, we changed it back and scheduled the new time and it worked just fine.
It was a big time useless mess.. thanks anyways for looking into it.
Nice, glad to hear it's working.
david
tim.moomaw
Script & Application been refreshed through Appadmin?
