Image not getting uploaded on 7942
bigcappa1 Fri, 03/06/2009 - 06:44
Neo,
I assume you have uploaded the TN-Gelogo.png, and the Gelogo.png to the same directory as the XML file.
Have you reset the TFTP service?
Paul
Jaime Valencia Fri, 03/06/2009 - 06:46
most common issued are you do not set the EXACT size or do not put the files in the right folder:
7942 / 7962
Full size image-320 pixels (width) X 196 pixels (height).
Thumbnail image-80 pixels (width) X 49 pixels (height).
Directory "/Desktops/320x196x4"
make sure it's all right, restart TFTP and try again
java
if this helps, please rate
Jaime Valencia Mon, 03/09/2009 - 08:36
exactly what do you see??
if you don't see the images, the list.xml file is wrong
if you see blue images, the images are wrong
java
Jaime Valencia Wed, 03/11/2009 - 10:35
had you already checked the list.xml file as i advised?
it's either wrong or in wrong directory.
if it was correct but images wrong you would get blue squares, but you're not getting that
java
