Redundant SUP Engine V fails to synchronize
Mar 6th, 2009
Hello Everyone,
I'm trying to configure an interface on the switch but the terminal/telnet stalls for a few moments and shows the following message:
11w2d: %HA_CONFIG_SYNC-3-LBL_CFGSYNC: Unable to sync due to IPC timeout or IPC rsp loss with current timeout(150) in second
11w2d: %HA_CONFIG_SYNC-3-LBL_CFGSYNC: Unable to sync cfg-changed cmd(int GigabitEthernet3/1) to standby
11w2d: %SYS-5-CONFIG_I: Configured from console by administrator on console
Need help on this. I can't configure anything on the switch, especially on the interface level.
Please anyone, badly need your help.
Ralph
miketennyson Fri, 03/06/2009 - 09:37
What OS version are you running? In the short term, have you tried simply removing the redundant sup so that you can make changes?
rgsuello84 Fri, 03/06/2009 - 17:44
here is my OS:
Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
About removing the redundant SUP, i don't want to try it out first until I am able to use all other means to make the synch work. Is this some kind of a bug or something?
Leo Laohoo Fri, 03/06/2009 - 17:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Have you tried using a different IOS?
rgsuello84 Fri, 03/06/2009 - 18:32
nope, not yet.. That may be our first step on the troubleshooting. I will give you feedback after i have done this.
