Guest configuration with WLC
Mar 6th, 2009
i am using WLC 4402 with firmware 5.1 and 1252 Access Point.
i am in trouble to configure guest access with the WLC.
i have configured interface in WLC under CONTROLLER->INTERFACES->GUEST.
WHEN I SELECT THIS INTERFACE AS GUEST IT DOESN'T TAKE IP ADDRESS INFORMATION. IN THIS CASE I HAVE TO UNCHECK GUEST SELECTION BOX.
AND I GOT DYNAMIC INTERFACE WITHOUT IP ADDRESS.
AFTER DOING THIS I CREATE WLAN NAMED GUEST AND ENABLED IT.
i have put guest interface as a ingress interface and management as egress interface and applied web auth successfully but still it is not showing me guest SSID when i try to search it.
help me
plz
thanks
runningboy01 Fri, 03/06/2009 - 05:44
Are you trying to create a SSID for guest access? If so, my suggestion would be to create a VLAN on a Layer3 Switch, create a DHCP scope, and create an Access List that allows internet only or whatever you would like. Then use that VLAN when you create your interface on the WLC. Leave guest unchecked and create interface as normal.
Scott Fella Fri, 03/06/2009 - 09:11
How you are configuring the wlc is for wired guest through the wlc and not wireless guest. So do you need help with wired or wireless?
If you have no guest anchor controller, then you need to setup an dynamic interface on the wlc and set the vlan id and ip address information. Then you need to make sure that vlan is forwarding in you network and you have a valid dhcp scope. On the wlan, set the interface to the one you just created and you are done.
Again... if you have another setup other than this, let us know.
Leo Laohoo Fri, 03/06/2009 - 15:03
Have you gone through these documents yet?
Wired Guest Access using Cisco WLAN Controllers Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808ed026.shtml
Guest WLAN and Internal WLAN using WLCs Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008070ba8f.shtml
Hope these will help you.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
