AD and CCM question
Mar 6th, 2009
  • Silver, 250 points or more
If you have existing CCM cluster already set up and deployed and now look to integrate AD into it
First install with AD
It is true that AD would delete details within CCM as part of the initial AD integration ? if so what ones
End User ?
UDP ?
Handsets?
I`m trying to gauge the impact of integrating AD in to an existing Cluster
Post install, every End User in CCM must come from AD- again is this correct or can you manually add them into CCM if so will AD after it does a synch delete them again as AD is not aware of them
many thanks
david-lima Fri, 03/06/2009 - 05:19
  • Bronze, 100 points or more
Hi friend, i understand that when using LDAP, some end-user data are no longer controlled via CUCM like: User ID
First, Middle, and Last Name
Manager User ID and Department
Phone Number and Mail ID, and password if LDAP authentication is used.
When use LDAP SYNC, users cannot be added or deleted from CUCM.
About SYNC process:
Synchronization process
- All existing CUCM end-user accounts are deactivated.
- LDAP end-user accounts that exist in CUCM(now deactivated) are activated and settings are updated (if different in LDAP).
- LDAP end-user accounts that exist in LDAP only are added to CUCM database (and activated).
- Deactivated accounts are purged from CUCM database after 24 hours.
Hope this help
David
Jaime Valencia Fri, 03/06/2009 - 06:34
  • Cisco Employee,
  • Hall of Fame,
    2011
version??
PLEASE ALWAYS PROVIDE VERSION
the behavior is different on windows and linux versions
java
if this helps, please rate
iptuser55 Fri, 03/06/2009 - 08:10
It was a generic question on both 4.x and 6.x- how much of a difference is there in principle?
Jaime Valencia Fri, 03/06/2009 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    2011
MAJOR
4.x does NOT delete anything
linux does delete accounts if no matches for the attribute
read SRND LDAP integration chapter for both version to understand all that is different
java
