6509 VSS VSL link
Mar 6th, 2009
I have 2 x 6509, each 6509 has 2 x Sup720 bundle with 10G port. Can I use 2 x Sup720 to form a
VSL link which make a VSS switch. I don't know can VSS can support redundency Sup720
Giuseppe Larosa Fri, 03/06/2009 - 08:02
  • Hall of Fame,
    Founding Member
Hello Jack,
VSS supports only one Sup per chassis
you need specific type of Sup for supporting VSS because the VSL exports the data plane and the signalling plane to make a single device
The Active Sup controls the linecards of both chassis.
see table 4-1
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
Hope to help
Giuseppe
